It is currently Fri Sep 20, 2019 4:29 pm
Post new topic Reply to topic  [ 319 posts ]  Go to page 1, 2, 3, 4, 5 ... 22  Next
PostPosted: Fri Feb 19, 2016 9:55 am
Online
WIND DIRECTION VANE
Achieve the most performance and optimal course. Up on the mast head is the least disturbed wind flow, so the optimal location for a wind direction vane. As the wind changes direction or oscillates, you need to adjust heading and or sail trim for best performance. This wind vane is designed for all Hobie Islands when not using a spinnaker kit. Simply slips over the mast head and tightens in place with a thumb screw.
72020356 MAST HEAD VANE $21.99 (USA / USD 2/2016)
HOBIE ISLAND SPINNAKER / REACHER KITS
Add performance sailing when reaching or running. The Hobie Island spinnaker kit includes a snuffer launching and retrieving bag which makes handling the spinnaker as easy as can be. Simply pull on the halyard line to launch, set the sheet and off you go! To lower, ease off the halyard and pull on the retrieval line. The spinnaker drops and stows directly into the snuffer system. The kit includes a mast head wind direction vane for use while rigged for the spinnaker. Note: Spinnakers can be challenging to rig / sail and may not be for the novice sailor. Consumers are advised to rig, test on land then learn to sail the spinnaker in light winds.
We will begin shipping Island Spinnaker kits late next week!
72020350 SPINNAKER KIT ADVENTURE ISLAND $589.00 (USA / USD 2/2016)
72020351 SPINNAKER KIT TANDEM ISLAND $639.00 (USA / USD 2/2016)
Island Spinnaker Instructions:http://static.hobiecat.com/item_attachments/72020350_72020351.pdf
We will also post a detailed instructional video shortly. The printed instructions have this link to it: http://www.hobiecat.com/islandspinnaker
PostPosted: Fri Feb 19, 2016 10:04 am
Awesome!!! Heading to my dealer today!!!
PostPosted: Fri Feb 19, 2016 12:03 pm
Great News. My dealer and I are all over it.
2015 Tandem Island
"The JoJo-B"
PostPosted: Fri Feb 19, 2016 1:07 pm
Thank you Matt, and the rest of the Hobie team. These 2 additions look awesome!
Joe
Crazy Joe
Captain of the LIC. Landlocked Island Club, Omaha Ne.
2016 Tandem Island on a Trailex Aluminum trailer being towed by a
Triumph Scrambler Motorcycle..
PostPosted: Fri Feb 19, 2016 2:15 pm
looks awesome, i can already see how i will route the lines to the rear seat for my liking......
PostPosted: Sat Feb 20, 2016 1:05 am
Who will be the one to post the first video?
PostPosted: Sat Feb 20, 2016 2:20 am
Matt,
Can we use the Mast Tip rotator to install a jib? for upwind performance
Tudor
PostPosted: Sat Feb 20, 2016 10:07 am
Looking forward! Is it already in Europe?
Enviado desde mi iPhone utilizando Tapatalk
http://www.youtube.com/user/educavendish?feature=mhee
PostPosted: Sat Feb 20, 2016 10:36 am
Any idea if the instructonal video incluse a guide to telling one's wife about the new reacher?
"You spent how much on WHAT?!?! It already has a sail!"
PostPosted: Sat Feb 20, 2016 5:46 pm
Matt, not a big deal but it looks like in the manual page 11 figure 17, it shows installing Harken single pulley on rear of kayak, then on page 2 the component list does not show the Harken single pulley........
PostPosted: Sat Feb 20, 2016 8:55 pm
Question - I understand why certain parts and pieces have to be different between the AI and TI, but is the sail itself the same size, shape, etc.?
PostPosted: Sat Feb 20, 2016 9:17 pm
Tom from the user guide it looks like the TI's is larger. There are three grommets that the snuffer line runs through as opposed to only 2 on the AI's.
"Third Normal Form"
  • Trampolines
  • Hobie cover
  • Davis Spar Fly
  • Kayakbob's Sprayskirts
  • Spine Board Hakas
PostPosted: Sun Feb 21, 2016 3:58 am
Which it is the spinnaker sail area?? :shock:
This new accessory is only for 2015 or more new! To mount the Harken Cam Cleat to the front cross
bar you need the tapped holes next to the other two Harken Cam Cleats, and this is only on the new island.
To adapt the Harken Cam Cletas on the old boats we need to do a modification. :?
Hobie Adventure Island (2014)
PostPosted: Sun Feb 21, 2016 6:14 am
Tom:
I'm sure Hobie will explain the differences, eventually.
At the last EC I sat and chatted with Jim for quite a while and he showed me the spin kits and we went thru them in detail. The sail material is similar to the material used on the screacher on your WETA (don't know what it's called, but I love that stuff).
I'm assuming the kit has not changed a lot since then. The kit is really well thought out and well designed (IMO).
The Adventure version looked to be an assymetric spinnaker (not a code zero screacher type), it looked to be around 60 sq ft on the adventure version and around 80 sq ft on the TI version (just rough guesses on my part).
My main concern seeing the design, and initially having the same issue with my spins early on. I told him if he doesn't shorten the battens on his main and tape over them there is a huge potential for the rear stay line to get wrapped around the batten posts on the main. If this happens your kind of screwed (especially in high wind). If that happens you can't furl the main, or bring the spin down (better have a big anchor and a knife at that point (lol).
If you furl the main in a few turns whenever the spin is out this becomes a non issue, or you can do like I did and run that rear stay line inside a piece of 3/8 pvc water pipe (the pvc prevents the stay line from getting tangled).
The only additional pointer I have is when using the spinnaker (especially in high winds) it's a pretty good idea to keep tension on the main control line to prevent the mast from bending too far forward. The problem is that little 1/4 inch stud at the base of the mast holder, too much forward force breaks that stud (I've broke quite a few). The other problem that creeps up if you allow the mast to bend too far forward is the normal lifting force from the spin becomes downward force and the boat will dive and pitchpole when you go over big boat wakes or rough offshore chop, I've pitch poled mine 4 times now (you go from 20 mph to zero in one second flat, the boat doesn't flip like a cat would, the bow just dives down about 3-4 ft), bring along plenty of AKA sheer bolts.
I'm sure everyone will figure all this stuff out for themselves via hard knocks, just thought I would share some of my trials and tribulations of using spins on TI's over the last 5-6 yrs. I still contend there is nothing more fun in sailing than launching a giant spinnaker and watching it fill with air (it's like a super charger), hang on to your hats folks, let the fun commence.... Just don't allow it to pop open too fast in heavy air, you will snap your mast.
FE
PostPosted: Sun Feb 21, 2016 8:41 pm
Be careful of gusting winds too.
I bent the mast on my Young 7.8 water ballast with a traveller that shouldn't have been up.
Hope Hobie Australia get at least one for me in their next shipment.
Tandem Island -
