vetgam wrote:
Here is a picture of the how the reacher's halyard was getting wound up on the mainsail.
This is similar to what happens with my AI2 and spinnaker. For several days I've been trying to make the spinnaker play nice with the mainsail. When I took it out on the water the first priority was to make sure furling the main was smooth. No go, tangle after tangle. I never did fly the spinnaker on the water. In my driveway the same problem keeps replicating. Similar to the picture vetgam posted of the front line hanging off the topper and grabbing the top of the mainsail.
Some of the wrapping and snagging can get pretty nasty so this could be a potentially dangerous situation. Different islands have different sails so maybe this isn't a problem on the tandems or older AI's. All my batons were shortened as short as possible too. I love the spinnaker and it flies and snuffs beautifully in my driveway. But I absolutely don't want my mainsail disabled in a busy channel or while beaching or when the wind gets too strong and you need to furl but can't. If the spinnaker is flying then this probably won't be a problem because the front halyard line is flying and positioned farther out front away from the mainsail. But if the spinnaker is in the bag this is where the problem is most prevalent because the front line is laying closer to the mast.
One modification I made was adding a snap clip to the halyard line that attaches to the head of the sail which is a quick way of disconnecting the spinnaker and you can possibly roll in main in an emergency snag. Plus the clip makes hoisting and taking down the mast easier. After hoisting, clip the line to the head of the spinnaker.
The only other option I can possibly think of is to relocate the snuffer bag to the outer edge of the tramp which may move the mast topper's front line slightly further outward from the mast but that's probably not a solution. I notice Vetgam has his bag mounted on the outer edge even though the Hobie video shows it in the middle which is what I did. The tangles occasionally happen to the rear topper line too. Those don't seem quite as critical as the front tangle. Might need to bring an extendable pole to dislodge the rear tangles.
It would be nice to hear from other 2015/2016 AI'2's with it installed to see what their tangling experiences are. Any ideas are also appreciated.
