It is currently Thu Apr 18, 2024 10:10 pm
PostPosted: Fri Aug 26, 2016 6:23 pm
I am adding my very long Lowrance Structure Scan Transducer to the rear of my kayak. The transducer is already bolted to a 6061 T6 aluminum plate that form fits perfectly to my hull. Now all I need to do is permanently attach the plate to the hull WITHOUT using any bolts, screws or modifying my hull in any way.
I am looking for permanent double sided tape, some sort of glue or any other methods that bonds to high density polyethylene.
Any body have any idea? I don't want the transducer popping off every time a gator wraps a line around it.
PostPosted: Wed Aug 31, 2016 8:07 am
you probably want to ask this in the kayak/fishing forums and not the sailing forums: viewforum.php?f=53
2014 T2
past: 1974 H14
PostPosted: Wed Aug 31, 2016 9:39 am
HDPE is difficult to bond (a couple years ago I would have said impossible)...especially in a marine environment. Suggest you Google HDPE glue and pick one of the new products...but I'd add a safety line to the aluminum just in case.
R/Thom
SeaRail 19
Triak
BMW C600
Formerly raced F24 Mk II
PostPosted: Thu Sep 01, 2016 3:32 pm
Have you considered one of the RAM transducer arm mounts for LSS1 & 2 (part no. 72023037)? This arm mount is specifically suited for the StructureScan, and would only require drilling to thru-bolt the RAM ball base to the gunnel of your kayak. Takes 1" RAM Ball.
Howie Strech
Parts & Accessories Product Manager
PostPosted: Fri Sep 02, 2016 12:24 pm
I would think hdpe would be invisible to your sonar head, just wondering if you can glue to the inside.
Just a thought
FE
PostPosted: Wed Sep 07, 2016 2:22 am
Check out 3M VHB double-sided tape.
http://solutions.3m.com/wps/portal/3M/en_US/Adhesives/Tapes/Brands/3M-VHB-Tape/
