It is currently Fri Aug 07, 2020 11:59 am
 Post subject: Tiger maintenance
PostPosted: Sat Dec 17, 2016 11:39 am
Hello All,
I'm looking for recommended maintenance advise for a 2004 vintage tiger. No obvious issues but I'm curious if there are particular areas to inspect or look for wear?
Corkguy H18, H20, Tiger
 Post subject: Re: Tiger maintenance
PostPosted: Sun Dec 18, 2016 6:20 am
Has the bottom been de-seamed? Not really maintenance, but it's something almost everyone did.
Daggerboard trunk leaks. Especially the aft end at the bottom.
Board tips - they're always finding the bottom. Cause of daggerboard trunk leaks
Usual aluminum / stainless steel interaction corrosion everywhere.
That's all I can remember from mine. Tigers are tanks.
PostPosted: Wed Dec 21, 2016 2:46 pm
Something about the tramp changed in ? 2008?....
I recall a design flaw that was causing the tramps to tear at the front corners....
So many Tigers are still sailing....
2015 H16, with spin,
PostPosted: Sat Dec 24, 2016 10:37 am
Thanks Matt,
Dagger boards and trunk are ok.
"Bottom been de-seamed?" This is something I'm not failure with. I assume I would look though the hatches for signs of glass being added from the inside?
PostPosted: Sat Dec 24, 2016 10:50 am
No - the original Tigers had a very obvious hull join seam on the outside at the centerline - like the ones in between the hatch plates on the decks.
Look underneath the boat - if it's all smooth, it's been de-seamed. Otherwise, it'll have a ~3/8" wide square seam that's pretty noticeable.
PostPosted: Mon Dec 26, 2016 9:58 am
H16's and H18's were built with a hull section, and a deck section.
Then the two parts were placed in a jib and glued together.
The lip provides a great deal of structural integrity.
The more modern Tiger is built in two halves, left and right, which are joined.
What Matt B said, look for the seam.
If the previous owner arrived in harbour 'hot', and hit the dock, it is possible in a collision like that for the bow to split open or 'de-seam'.
Same for the bottom of the hulls.
The one Tiger I used to crew on got blown away one time, landed on the rocks.
It only suffered cosmetic damage....tough as a tank.
