It is currently Tue Apr 23, 2024 4:05 pm
Post new topic Reply to topic  [ 45 posts ]  Go to page 1, 2, 3  Next
PostPosted: Sun Mar 26, 2017 6:54 pm
I installed my Spinnaker kit last night and I'm not a big fan of the red halyard line running to the eyelet post on the aka. did anyone swap them out for pulleys? Another thing, the kit comes with pad eyes but I think I'm going to use a cheek block. I think the pad eye will create more friction and cause more wear and tear on the blue halyard line. Anyone else use a cheek block or a pulley of some sort?
Sent from my XT1585 using Tapatalk
PostPosted: Sun Mar 26, 2017 7:05 pm
I haven't gotten the admiral to approve funding for a spinnaker yet. However, it is in the works, and when I do install it I plan on ditching the posts on the akas for a soft shackled pulley. I also plan on routing the sheets back to soft shackled pulleys on the rear padeye of the amas.
"Third Normal Form"
  • Trampolines
  • Hobie cover
  • Davis Spar Fly
  • Kayakbob's Sprayskirts
  • Spine Board Hakas
PostPosted: Sun Mar 26, 2017 7:48 pm
When I bought my TI, I made sure to get the Spinnaker kit wether or not I ever want it or need it. I usually persuade my accountant during night time.
PostPosted: Mon Mar 27, 2017 5:01 am
There is a reason to use posts vs a pulley/block.. The ideal position/angle of the spin sheet coming from the aka varies depending on if you are running or going upwind. If you use a block, you are locked into that one position and you will find limited use of the spinnaker. The reason to install the spin cleat within 4 inches of the aka knucle is because that is the perfect upwind position. I installed the post out as far as i could confortably reach. I pull the sheet semi tight before wrapping it around the post and then make my final adjustment.
Greg
2016 AI - Spinn & Jib
– Charles G. Davis
PostPosted: Mon Mar 27, 2017 5:21 am
But aren't you locked into one position by using the post? Maybe because I don't have one yet I'm not fully understanding the drawbacks of using a soft shackled block vs. a post. Regardless of post or block I plan on routing my sheet out to the rear of the ama anyways. This is not an upwind sail and is meant to be used on a reach or run.
"Third Normal Form"
  • Trampolines
  • Hobie cover
  • Davis Spar Fly
  • Spine Board Hakas
PostPosted: Mon Mar 27, 2017 5:43 am
Tom, you will be pleasently suprised. I've been safely using this sail upwind for over a year now, as do the people I sail with. I would go as far as to say I sail more upwind with it than I do downwind on days where the winds are less than 12mph. Hobie is understandably playing it safe by calling this a downwind only sail. But the cut of this spinnaker is much like a code zero sail which is meant to be a spinnaker that can be sailed upwind too. This doubles the potential of Hobie's sail. I promise, once you try it upwind you will use it that way. You just have to be careful and bring it down if your heeling to much or experiencing gusts. You can't effectively point upwind if the spin is being held out by a post or a block. It has to be pulled in tight.
Greg
– Charles G. Davis
PostPosted: Mon Mar 27, 2017 5:56 am
Here is a link to a video showing the spinnaker being used upwind. It I feels to me like it almost doubles my spead vs main alone but I have never measured it. There is no undo strain on your boat in light winds. You wont point as well as main only but you definitely sail upwind. I was moving very slow upwind before pulling out the spinnaker in the video below.
https://youtu.be/Fy4QdYKwfJw
When wing the spinnaker this way, I now unfurl the main all the way out and pull it tight. This Adds speed.
Greg
– Charles G. Davis
PostPosted: Mon Mar 27, 2017 6:18 am
So, that's sort of what I'm trying to fix. With a soft shackle you should be able to slide the block along the aka to either place it inboard or outboard depending on your point of sail. Almost like a traveler car. This is the block I'm thinking of:
https://www.amazon.com/dp/B00A17O83C/ref=wl_it_dp_o_pd_S_ttl?_encoding=UTF8&colid=2IKUB0W6XRFVE&coliid=I3TZ2T1M84B0VY
or even this one
https://www.amazon.com/dp/B00CSXZ24G/ref=wl_it_dp_o_pC_S_ttl?_encoding=UTF8&colid=2IKUB0W6XRFVE&coliid=IRJE6NQRG5IOR
"Third Normal Form"
  • Trampolines
  • Hobie cover
  • Davis Spar Fly
  • Spine Board Hakas
PostPosted: Mon Mar 27, 2017 6:30 am
Vetgam,
Here is a video of the setup that I was talking about. This is video is Spook hitting some impressive speeds, and I believe TonyScott has implemented a similar block style system.
"Third Normal Form"
  • Trampolines
  • Hobie cover
  • Davis Spar Fly
  • Spine Board Hakas
PostPosted: Mon Mar 27, 2017 6:53 am
What I would suggest is that what Spook gains downwind, he loses upwind because he can't change the spinnaker's sheeting angle for upwind use. Correct? I'm not comfortable with the trade off. You can't point upwind well with the spinnaker that far out. Maybe he is using a post on the aka to pull the sheet in upwind but I've seen his setup and don't recall he did that. If he did that I would suspect the angle to the post would make it slip off. I like those soft blocks though. Never seen them before.
Greg
– Charles G. Davis
PostPosted: Mon Mar 27, 2017 7:19 am
I'm thinking of a trade-off. Don't use blocks at the back of the ama. Instead just use soft shackled blocks on the rear aka that you can slide in and out depending on upwind or downwind. Looking at another trimaran that has a "reacher" (a corsair pulse 600) they have their spinnaker sheets routed from the tack of the sail to a turning block on the back of their aka and then forward to another turning block. The only difference between their setup and what I'm proposing is the extra run back up to the front aka as well as the fixed location of the turning block on the rear aka. Not to mention their akas are much beefier than ours. Here is a video that shows their setup:
"Third Normal Form"
  • Trampolines
  • Hobie cover
  • Davis Spar Fly
  • Spine Board Hakas
PostPosted: Mon Mar 27, 2017 8:28 am
I see where your going with this now. Clever. A boom hitch knot tied to a block would work but you would be limited to how close in you can pull the block in due to the u-shaped aka brace and it's holder. The ideal sheeting angle should be about 7 degrees off the bow for upwind use. That's about 2-4 inches out from the back akas knuckle..
Greg
– Charles G. Davis
PostPosted: Mon Mar 27, 2017 8:43 am
You could tie rope from one eND of the aka to the other and then tie the block to the roperson with a boom hitch allowing you to bypass the aka brace and support.and slide the block as needed.
Greg
– Charles G. Davis
PostPosted: Mon Mar 27, 2017 8:53 am
Would you be able to slide the boom hitch on the rope? I've never used a boom hitch. I remember someone on the forum talking about one though. Maybe that was you? :oops:
"Third Normal Form"
  • Trampolines
  • Hobie cover
  • Davis Spar Fly
  • Spine Board Hakas
PostPosted: Mon Mar 27, 2017 10:36 am
It is suppose to work rope to rope. Monohull sailors use it to release pressure on a sails sheet while fixing a fouled wench. I don't have any experience rope to rope.though.
Greg
– Charles G. Davis
