It is currently Tue Apr 23, 2024 7:52 am
 Post subject: Hobie cart
PostPosted: Fri May 26, 2017 4:15 am
Hi fellow members,
Does anyone has experience to bungee the Hobie cart in the two factory holes and use all the way to fishing without taking it out until finish?
Thanks in advance!
 Post subject: Re: Hobie cart
PostPosted: Fri May 26, 2017 6:22 am
crappie wrote:
Hi fellow members,
Thanks in advance!
You mean...leave the cart plugged in, under the kayak, while you're on the water? How would you use the mirage drive?
PostPosted: Fri May 26, 2017 8:35 am
reason162 wrote:
crappie wrote:
Hi fellow members,
Thanks in advance!
Thanks for your reply and yes.
If I leave the cart plug in, can I still use the mirage drive?
PostPosted: Fri May 26, 2017 9:06 pm
Yes, the Mirage drive will still work with the Hobie cart plugged into the hull UNDER WATER, But the amount of drag it induces, will make you wonder, why does the kayak not move very well in the water. :roll:
Dr.SteelheadCatcher
Warrenton, OR
PostPosted: Sat May 27, 2017 1:00 am
I don't think the mirage drive is going to work with the cart plugged in, not on the inflatable models.
PostPosted: Sat May 27, 2017 8:57 am
agreed, inflatables have no scupper holes, the cart plugs in through the drive well and would block you from installing the drive...
2019 Outback360 'Fish Retriever'
2016 i11s 'Go Cougs!'
2012 Oasis and 2012 PA12 (moved on but not forgotten...)
PostPosted: Mon Jun 12, 2017 9:32 pm
As can be seen in the original 2008 I-12s below, the inflatable cart has always been mounted in the drivewell insert. The scuppers were not plug-ins for a cart and were normally capped from the top. i-14Ts and i-9s had the same arrangement.
Launching with a cart in is a mistake that is noticed immediately (no speed) and could be destructive to the cart if it were to hit an underwater obstruction. :? Fin use would be pretty darned limited with a cart attached!
gif image hosting
PostPosted: Fri Jun 16, 2017 3:40 am
Thanks for the photo and reply
