It is currently Tue Apr 23, 2024 9:43 pm
Post new topic Reply to topic  [ 1315 posts ]  Go to page Previous  1 ... 83, 84, 85, 86, 87, 88  Next
PostPosted: Sun Aug 13, 2017 1:53 am
Great pics Bryan! Is your TI perched on that rock due to tidal variation?
Thanks for the spineboard info.
Can you walk on those spine boards OK? I often exit my TI standing on my haka.
PostPosted: Sun Aug 13, 2017 2:00 am
Nice work with those red spine boards Tom! 8) Not having to remove them is a bonus.
I'm just wondering why so far out? In that position you'd be dragging the ama when hiked out in all but the strongest of winds.
PostPosted: Sun Aug 13, 2017 7:06 am
They are more for my kids to sit on. My wife was worried that I would not leave them enough trampoline to sit on with the hakas installed. With the Railblaza mounts I can side the hakas inboard if the tramps aren't installed.
Sent from my SM-G950U using Tapatalk
"Third Normal Form"
  • Trampolines
  • Hobie cover
  • Davis Spar Fly
  • Kayakbob's Sprayskirts
  • Spine Board Hakas
PostPosted: Sun Aug 13, 2017 9:47 am
Good idea with the swivel mounts Bob! Really nice work!
Do you know how much weight thoose swivel mounts can handle if you stand on the edge of the spine board. Any risk of beraking them?
All the best!
/Gustav
Sailing my TI and fishing.... thats bliss!!
PostPosted: Sun Aug 13, 2017 2:41 pm
Once you've tried sitting on haka I'd be very surprised if you preferred the tramps! Haka have many advantages over the tramps - higher, drier, easier to access, easier to grab, easier to adjust seating position etc.
Tramps are great but haka are better!
PostPosted: Sun Aug 13, 2017 8:26 pm
I'm sure I will sit on them myself. I made up some PVC supports using 1 1/4" x 1" tees cut into saddles. The 1 1/4" snaps right over the aka bar. I then used a 3/4" slip to 3/4" threaded adapter. The 3/4" slip end loosely fits into the 1" portion of the tees. The 3/4" threaded end then mates with a 3/4" saddle tee that is perpendicular to the 1 1/4" homemade saddle tees. The 3/4" saddle fits right onto one of the underside ribs on the spine board. When I want to fold everything up I just rotate the supports out of the way. It was dark by the time I was done so I didn't get pictures. I will try to get some tomorrow.
"Third Normal Form"
  • Trampolines
  • Hobie cover
  • Davis Spar Fly
  • Spine Board Hakas
PostPosted: Mon Aug 14, 2017 11:57 am
Great stuff, guys. Keep (t)railblazin! :mrgreen:
The Wind Is Your Friend...
PostPosted: Mon Aug 14, 2017 2:03 pm
Yep, tide. It was 11.7 to -.02 that day. Almost 12 feet. Of note, I am going to get some beach rollers that will work better on uneven rock than the slide over driftwood method. We also haul out with 250 feet of line or anchor and paddle board in. That island has horrible anchor bottom and a tidal current that is impressive! Better to haul sometimes.
Sent from my Z958 using Tapatalk
Bryan "Cujo" Edmonds
2015 Tandem Island "Supernova"
2014 Lund SSV18
PostPosted: Mon Aug 14, 2017 2:04 pm
Walking is no problem bending wise. My brand is slick as snot so putting on waterproof padding is a must for standing
2014 Lund SSV18
PostPosted: Mon Aug 14, 2017 5:54 pm
I got around to taking pictures of my PVC supports. I made 2 for the rear and 2 for the front. Right now I'm only going to use the rear unless further testing dictates. Since the boards narrow at one end it almost ends up being supported tripod style. I don't envision much weight to the front anyhow. The first pictures are the rear supports, followed by a shot of how they snap on and swivel out of the way and finally a picture of the front supports. ImageImageImageImage
"Third Normal Form"
  • Trampolines
  • Hobie cover
  • Davis Spar Fly
  • Spine Board Hakas
PostPosted: Fri Aug 25, 2017 6:32 am
Hakas!!
New delivery today, the spine boards I ordered from a surplus company in Germany arrived. :D
They are a bit scuffed and scratched but otherwise in very good condition. No cracks or sign of hard use.
The "military look" will look pretty cool ... I hope! 8)
I just put them loosley in place on the akas to check them out... wow.. they really do makes the TI look larger somehow?
The underside is pretty flat so for starters I will just strap them onto the akas and maybe later work out a better sollution to keep them better in place.
Disadvantages.....? Well this ads another 20Lbs to my "Yak"!
It sure will be interesting to see how the TI will sail with the extra weight?
:mrgreen:
PostPosted: Tue Sep 05, 2017 3:36 pm
Got to test out the hakas last weekend. They worked pretty well especially for the kids. I'm a little too heavy for the current mounting setup. Even with the PVC support I produced enough torque on the railblaza swivel ports to pop them out. ImageImageImageImage
"Third Normal Form"
  • Trampolines
  • Hobie cover
  • Davis Spar Fly
  • Spine Board Hakas
PostPosted: Fri Sep 22, 2017 2:17 pm
Mine are made of fiberglass slatted planks. Used on offshore oil rigs. Yoga mats on top. Had them over a year. They are mounted with camera lighting mounts, this allows them to swivel so i never have to remove. Also they are strong enough to hold my weight 200 lbs standing in the middle. They are lighter than wood and because they are slatted they allow for multiple fitting locations. If I only had made them longer. https://www.flickr.com/photos/159644655 ... res/3825Vg
PostPosted: Sat Sep 23, 2017 2:30 pm
Those haka look good LCB, nice work! 8)
We’ve had wood, aluminium, steel and plastic haka and now you have introduced fibreglass planks. Any more details, links etc? I’d like to know a bit more about them.
PostPosted: Sat Sep 23, 2017 3:05 pm
+1 Stringy
2015 Tandem Island - Golden Papaya "HALIBOO"
(retired) Outback - Hibiscus Red
