It is currently Sat Sep 26, 2020 3:34 pm
 Post subject: Grease
PostPosted: Sun Nov 05, 2017 9:40 am
What kind of grease should I use to service a GT Mirage drive?Will regular Marine grade grease harm the plastic parts?I wonder what kind Hobie uses at the factory.
Andrew
 Post subject: Re: Grease
PostPosted: Mon Nov 06, 2017 7:03 am
Some people do nothing. I spray the parts with a good silicone spray. If you put grease on, there may be a tendency to pick up sand.
PostPosted: Mon Nov 06, 2017 5:10 pm
I want to tear down the idler pulley.both sprockets and the drums. On the GT Mirage drive they all have needle bearings that ride on the shafts and need to be cleaned and re greased periodically.The factory grease was green in color.I just wonder what kind of grease Hobie uses.I do not want the plastic parts to be degraded by using the wrong product.
Andrew
P.S I think I found my answer.Here it is if anyone else is interested.
https://www.hobie.com/forums/viewtopic.php?f=11&t=57392
PostPosted: Tue Nov 14, 2017 10:55 pm
Any marine grease works. Other greases will wash out. IMO, all three shafts should be greased (idler, drum and sprocket) regardless of what model Drive you have. 8)
