It is currently Fri Jan 19, 2018 12:41 pm
 Post subject: Mast support extension
PostPosted: Thu Feb 19, 2004 7:37 am
I tow my H16 behind a full size Chevy Express van.
The front mast support is a two-piece unit that is extended to its maximum height but, due to the height of my van, the mast isn't high enough to go over the top of the van.
I've been thinking about fabricating an extension so I can get the mast over the top of the van and, thus, have more of the weight evenly distributed and not have as much hanging off the back of the boat.
Any ideas? Suggestions?
Thanks!
Nick
 Post subject: Re: Mast support
PostPosted: Thu Feb 19, 2004 8:49 am
A couple of questions, is the rear of your mast supported at all, or does it sit on the rear edge of the boat?.
When you have the boat hooked up to your van, is the trailer sitting level?
How does your front support extend? This could be very helpful in giving you some help with this.
Could you also possibly provide any pictures so we can get a better idea of what you are working with?
I know that I have towed my 16 with a mini van and a F150 with a cap on it with no problems to speak of, the mast clears the roof on both of them.
Mark Colby
1973 H16
PostPosted: Thu Feb 19, 2004 10:16 am
Thanks for the reply, Mark!
To answer your questions:
1) The mast rests on a mast support hooked to the rear beam of the boat.
2) Yes, the trailer is level when attached to the van.
3) The front mast support is a two piece, metal extension support that uses bolts to set the height. It is currently at its highest level and brings the mast to about 6 inches below the top of the van.
I'll try to post a pic later today.
Thanks again!
Nick
1978 H16 "Burt The Cat"
PostPosted: Thu Feb 19, 2004 10:41 am
Authorized Hobie Dealer
Move the mast support farther back. Just a little will dramatically change the angle and should provide enough clearance 9 times out of 10 this will help. Let me know if you have any questions. Also where it is supported on the rear cross bar how high does it stick up? You may need to get another type of cradled to lower that back end a bit. Hobie had a nice on that is held on with bungi and is made to fit on the H16 rear cross bar. Part number 3175 and is on page 45 of your Hobie Parts and Accessories catalog.
Brad Stephens
www.sunjammers.com<------new site!
Authorized Hobie/Vanguard Dealer
Division 15 Chairman
Panama City Beach, FL
brad@sunjammers.com
850-235-2281
PostPosted: Thu Feb 19, 2004 12:46 pm
Thanks, Brad!
I'll check that out.
My rear mast support is the type that slides into the traveler groove and bolts down. It's as low as it's gonna go!
Fair Winds,
Nick
 Post subject: Mast Support
PostPosted: Fri Feb 20, 2004 1:10 pm
Nick,
where are you in Michigan, I am in the Jackson area and willing to come over and help you with your project.
Thanks for the answers to the questions, that does help out a lot. Is your front mast support such that it can be moved further back? I know the one on my trailor is welded into postion and cannot be moved at all, and it does not have a height adjustment to it.
Have you tried too change the angle of the front mast support yet?
You can email me at mecolby@comcast.net if you want to get together.
Mark Colby
1973 H16
PostPosted: Mon Feb 23, 2004 7:32 am
MarK;
I'm located in Lansing.
Checked the trailer and it does appear to have the type of support that can be moved back. When the weather gets warmer, I'll play around with it and see if I can get the height I need.
Thanks for the offer of help! I'll definitely take you up on that if need be. Perhaps we can get together some time and kick back some cold ones while discussing sailing? Or better yet, do some sailing (when the weather gets warmer, of course)!
Cheers,
Nick
PostPosted: Mon Feb 23, 2004 12:09 pm
Just a 1/2 hour away... Just an FYI, I am also in the process of trying to rebuild a Hobie fleet down here in Jackson, possibly on Clark Lake or Michigan Center Lake...
I haven't had the chance to check either lake out yet with the cat, but I have heard that both are good to sail on.
Mark Colby
1973 Hobie 16
PostPosted: Tue Jul 20, 2004 7:46 pm
Mark Colby
1973 Hobie 16
I am interested in your Hobie Fleet. I just recently bought a hobie 16 and have been looking for someone to sail with, I am in the Jackson area. Now keep in mind I am VERY new to Hobie sailing. If you have any more info on starting a fleet or even maybe I could get some pointers on sailing let me know
jriske3@hotmail.com
