It is currently Thu May 28, 2020 9:24 pm
PostPosted: Sat Jan 14, 2017 2:35 am
Vantage CT seats from our '16 Oasis fitted to our '10 TI.
I had previously raised the seats to get out of the puddle but no longer need all this:
...which gives us extra storage space under the seats:
PostPosted: Sat Jan 14, 2017 8:20 pm
Talk about upgrading! So when are you fitting 180 drives? Cool mod Stringy.
PostPosted: Sat Jan 14, 2017 8:37 pm
Hefty lift in the centre of gravity. I guess you can get away with that on a TI.
PostPosted: Mon Jan 16, 2017 10:17 am
Very nice Stringy! Well done.
PostPosted: Mon Jan 16, 2017 10:25 am
If Anyone could do it, Stringy would!
http://KayakingBob.com - - - - - - - - - - Hobie Island Sailing since 2006 - - - - - - - - - - SpraySkirts
PostPosted: Mon Jan 16, 2017 10:50 am
Stringy, that is well done! Looks like they came that way.
Greg
2016 AI - Spinn & Jib
– Charles G. Davis
PostPosted: Mon Jan 16, 2017 5:43 pm
Thanks guys! :)
This is a mod that is really only viable if, like me, you already had the Vantage seats on another kayak. At AUD$575 for each seat it wouldn't be worth it, especially as you don't get the adjustable thigh support.
Still, my wife and I are are very happy with this mod. You certainly sit higher and drier and the comfort and breathability of the seats is a great improvement over what we had before. The under seat storage is an added bonus and they do make great camp chairs as well.
It was actually a pretty simple mod to do. The Vantage seats lend themselves to a number of mounting options. I used 20mm alloy channel sitting in a 25mm channel for quick release so that I can refit the original seats easily if needed. I could have gone with 25mm/1" Bimini tube. The tube would need an indentation for the thigh support lever tab. It may also be possible to use the feet and floor mounts from the Vantage Pro Angler seat in place of the rear saddles I fitted. I'm checking out part numbers with my dealer.
As LB points out the C of G is raised but that is not an issue with the TI. Sitting higher makes it easier to swap sides when hiking out.
It is probably an issue in kayak mode but we've yet to test that.
PostPosted: Mon Jan 16, 2017 6:26 pm
Very neat mod Stringy. They certainly are a comfortable seat. I suspect that the higher CofG is only an issue in kayak mode. I haven't tried it yet to see how much more unstable it is though.
PostPosted: Mon Jan 16, 2017 9:21 pm
Thanks Slaughter. Sounds like you've upgraded?
AI2?
PostPosted: Mon Jan 16, 2017 11:19 pm
Looks good. But better is an Attwood with the older TI's and AI's. No need for any modification and they make great beach seats. Far more comfortable in my opinion. Not cheap. But, if you have a couple extra vantage seats, I can understand putting them to good use. I take it you will move them back and forth from the Oasis to TI, as used? Good idea!!
Mark
Tandem Island- 2013
2 - Sports - 2014
PostPosted: Tue Jan 17, 2017 6:48 pm
Nah mate. Still got the V2 AI with the skipper seat mod. Hard to justify the change over just yet. (but it will happen)
PostPosted: Wed Jan 18, 2017 1:20 am
It's time, Slaughter, it is time! The AI 2 is such an improvement. Why wait?
Again, nice seat mod, Stringy. :-)
PostPosted: Fri Apr 27, 2018 7:42 am
Good morning,
Would you be so kind to share more detail on this modification?
PostPosted: Fri Apr 27, 2018 11:52 am
Nicely done stringy! Those look like you'll stay even drier than a Vantage Seat in a new boat.
I have been waiting a couple of years to see someone hack a Vantage into an old boat... am I right that this is the first one? Surprised it took that long!
PostPosted: Sat Apr 28, 2018 12:09 am
Farrarkc wrote:
Good morning,
Hi Farrarkc,
There are many ways that CT seats could be fitted. I just used what I had on hand. The rear is easy- saddles self tapped through the hull. The saddles fit into the rear seat receivers for the beach seat legs. I added a bungee loop over a button on the hull in place of the standard rear webbing retainer as I didn’t have the female clip.
The front was a bit more challenging. You need something strong enough to span the gunwales and take your weight. I used 20mm U-section aluminium tube (leftovers from a DIY louvre kit). You could use 1” Bimini tube. The CT seat has a half pipe section of frame at the front that sits nicely on the tube. At each end where the squared off sections that fit the genuine height adjusters are I added a nylon ‘spacer’ that takes most of the weight. Velcro straps secure the seat to the tube. The front seat mount needed a small bracket fitted to the side of the gunwale as the Centreboard surrounds leave little gunwale. The tube/brackets at the front are through bolted using stainless M6 bolts and stainless ‘channel’ nuts inside the gunnel that don’t need holding with a spanner when fitting.
We really like the CT seats comfort and airiness and the higher seating position which is much drier, makes access easier and helps when swapping from seat to haka when hiking out. Using the CT seats as beach seats is also handy.
If and when I upgrade I hope the later hull high position on the CT seats is as high. If not, I’d have to look at doing the mod again -its that good! Previously the furled sail mainsheet used to sit annoyingly on my shoulder. Now it sits under my arm, which isn’t as annoying.
The negative with this mod would be the higher centre of gravity in kayak (hull only) mode. I made the tube to be easily removable (used M6 eyebolts/eyenuts) so that the original seats could be refitted if needed.
