It is currently Thu Apr 25, 2024 4:38 am
PostPosted: Thu May 10, 2018 12:46 pm
Some new items I found for the Torqeedo Ultralight -
https://www.innovativesportsman.com/sto ... light.html
I read about the cavitation problem, looks like there's a fix with that aftermarket drop pipe that just came out
PostPosted: Fri May 11, 2018 5:07 am
I've hit rocks with my Torqeedo, didn't seem to bother it a bit, it just rotates upward. Didn't hurt the prop or the skeg either, not even a scratch. So I'm not sure why anyone would spend $180 for a rock guard.
The cavitation is easily fixed by lowering the prop shaft a few inches deeper into the water. I've found a way to do this with a few simple parts which easily allow the 403 to be adjustable to any depth on the TI.
PostPosted: Fri May 11, 2018 8:20 am
IMHO, not only the $140 is way too much for the value (I will know more once I start using my 403 on rocky shallow areas), but the whole concoction looks somehow overwhelming: there is a "functional debt" incurred when convoluted solutions are applied to simple designs. In this case, the Ultralight assembly is already debt enough :)
In the same page, the vendor shows a $50 warped tube to lower the motor 2 inches: look closely at it, and it is just bent mechanically (you can see the tube compression on the bends). For $50, I nuy me a great vise, bend it myself, and keep the vise as extra :P
PostPosted: Fri May 11, 2018 5:58 pm
Thanks for the feedback guys. I'm still trying to swallow the price tag of the Torqeedo (especially since I have to add on shipping and duty to this little island) but I currently can't come up with a reason not to spend the money.
PostPosted: Sat May 12, 2018 9:06 pm
zorzal wrote:
...In the same page, the vendor shows a $50 warped tube to lower the motor 2 inches: look closely at it, and it is just bent mechanically (you can see the tube compression on the bends). For $50, I nuy me a great vise, bend it myself, and keep the vise as extra :P
I wouldn't buy that tube either. Due to varying loads and load distribution, the 403 should have a means of adjusting the depth.
Using parts available from Torqeedo I rigged the mount to be adjustable:
The photos above don't show it but the aluminium plate has holes to mount the 403 at adjustable depths.
