It is currently Wed Apr 24, 2024 11:51 pm
PostPosted: Mon May 21, 2018 2:17 pm
My vantage ct seat is stuck reclined all the way back and will not retract back upright. Pulling the recliner adjustment lever does nothing. Does anyone know how to repair this? It is from a 2015 Outback and no longer in warranty.
PostPosted: Mon May 21, 2018 4:37 pm
I think I replied to you on the Facebook user group too FYI.
Pull the back cover off the crossbrace with the recline lever - (8 small philips screw) likely the line has jumped off the pulley inside on the end, hopefully easy fix/
Jacques Bernier
http://www.hobie.com/
PostPosted: Tue Jun 28, 2022 10:46 pm
Vantage CT seat recline failed. Opened up the mechanism and see that The long flat ribbed piece that engages with the mechanism broke on the left side where the white line attaches to it. How would I get a replacement part to conduct the repair?
PostPosted: Wed Jun 29, 2022 10:22 am
Hobie Tech / Moderator
You need a replacement Linear gear - PN865072. An authorized Hobie dealer will be able to source this part for you.
[Image
