It is currently Fri Apr 19, 2024 11:39 am
PostPosted: Tue Aug 14, 2018 7:26 pm
Is this stock or did the previous owner add these for support? If added and they seem a little loose/compressed now, should I add new ones and also is there any other method to shore up this are?
Thank you,
Roy Niswanger
PostPosted: Mon Aug 20, 2018 11:06 am
The foam blocks support the deck from standing and sitting in your PA and was standard on your PA.
PostPosted: Thu Aug 30, 2018 6:33 pm
Great thank you so they are stock, OEM...I want to add more these things are getting soft and I need support, esp since I weigh 233 pounds.
Thank you,
Roy Niswanger
