It is currently Fri Jul 10, 2020 6:53 pm
 Post subject: Boondox modification
PostPosted: Sun May 06, 2018 1:07 pm
While I was surfing for installation info I came across an article where someone added a 1" block under the landing gear mount for extra support. (Helps to prevent hull cracking). Now I can not find the article and wanted to get he details. Has anyone done a setup like this?
 Post subject: Re: Boondox modification
PostPosted: Mon May 07, 2018 5:12 pm
Where would one add this 1" block? You can't lift the knuckle as you'd not fit under the H Rail.
PostPosted: Thu Jul 12, 2018 2:37 am
Blocks will only work on PA14 models take note of location of Hobie live well also
PostPosted: Tue Aug 28, 2018 5:33 pm
I may be wrong but the installation kit for the PA14 comes with a thin spacer to allow the unaltered boonedox to fit under the H-rail. Didn't look like there would be any room for anything other than the factory items.
PostPosted: Thu Aug 30, 2018 1:19 pm
Recently installed Boonedox on a 2017 PA 14, yellow. I ordered the kit for the Camo version because it comes with the 9" backing plate. The Camo versions may have been thinner or weaker hod some reports of cracking causing Boonedox to add more support. The non-camo version uses a 6" long backing plate. I figured the more support the better. The Boonedox aluminum casting fits tight under the H-rail so it offers slightly more support through the H-rail. So far, I'm happy with it.
