It is currently Tue Apr 23, 2024 3:01 am
PostPosted: Tue Jan 01, 2019 3:37 pm
I am going to be in the market for a new Hobie soon. I am debating on getting a Revo 16, Revo 13, or possibly a used 2018 or older Outback or PA14. I am not sure on the stability of the Revos, I currently use a Tarpon 160i (old version) and have no issues with the stability in it and I love the speed when fishing offshore. Is the Revo 16 similar in terms of stability? Is the Revo 13 more or less stable than the 16?
I fish a lot, and from late Spring until Fall I fish almost exclusively offshore out to around 6 miles. I have thought about a used PA14 since they are going so cheap but in Florida we have to haul the kayak through the sand and I am kind of scared with how much the PA weighs. The outback is only on the potential list since so many of the older versions are selling very cheap and rigged already. I already have a compass and I use it mostly inshore. I mainly use my Tarpon 160 offshore, it is a speed machine, which makes me think I would like a Revo, just not sure if how they are in relation to stability compared to the Tarpon. I am comfortable in the Tarpon and fish it alot, but it is about as tippy as I would be comfortable in.
So any recommendations? Thanks for any suggestions
PostPosted: Tue Jan 01, 2019 5:39 pm
Stability runs both ways. Boats that tend to be stable on flat water tend to be unstable in heavy chop and swell. Conversely, boats that are less stable on flat water tend to be more stable in the same heavy chop and swell. Kind of like the stability between a 4x8 sheet of plywood and a log. Imagine both on flat water, and then on rolling water, and how each will act in each situation.
So for mostly flat water, the PA, Outback, etc., are very stable. On rougher water I'd rather be in a Revolution, 13 or 16.
The Revo 16 is faster than the Tarpon 160. Stability seems about the same to me and the addition of the Mirage Drive gives the Revo a large advantage, in my opinion.
PostPosted: Tue Jan 01, 2019 7:42 pm
Since you have experience with the Tarpon offshore, the Revo 16 would be a good choice for you. I have spent many hours fishing out of a Revo 13 both inshore and offshore and never found stability to be an issue. When getting to your fishing spot quickly is a priority the Revo is the best choice.
PostPosted: Wed Jan 02, 2019 4:51 am
The revo 16 has a unique advantage in that you can drop a dagger board in for extra primary stability as required. I do that when at anchor or drifting, reduces the "twitch" when you are focused doing other things. Also helps in really bumpy conditions. I use a shorter DIY version as the hobie one is meant for sailing purposes. Helps track better, without limiting manoeuvrability if you decide to have a go at paddling. Pull it out when not needed so its not adding drag.
If you are happy with the tarpon then any other hobie will feel like a barge.
PostPosted: Wed Jan 02, 2019 9:50 pm
Sounds like you’re real happy with your tarpon for all the reasons that make a tarpon 16.
Agree with above that you won’t be happy in any other hobie ‘cause a dirty little secret is they’re all slugs except for the adventure (revo 16.) And as mentioned you’ve got the skeg for added stability, though you might lose some initially because I’m pretty sure you sit lower in the tarpon.
PostPosted: Thu Jan 03, 2019 6:14 am
Are you guys calling my beloved Outback a slug?! :lol:
I've been tracking my trips in the Outback for a while now and anything much above 5 knots is slamming into the limitations of the hull.
With the sail, good wind and peddling vigorously you can get above 6 knots but it becomes real clear that it's wasted effort.
For me, the Outback is perfectly fine because I'm comfortable sailing it in moderately bad conditions and since I don't live where I keep my boat, I want the widest usage envelope for the best odds of getting out on the water on those weekends get out to Cedar Key. I understand that the Revo can take rough seas very well when peddling without a sail, but I still think that the Outback has a wider sailing envelope.
Having said that, if you are accustomed to something sleaker that can actually be paddled more than occasionally, then the Outback won't be the right yak for you.
2014 Outback
2016 Outfitter
2017 Sport
PostPosted: Thu Jan 03, 2019 5:12 pm
Then your mates buy STEALTH fibreglass sit on tops and you feel like you are the only one bringing a revo16/adventure bathtub to the party.
Point is it is all relative to what you are used to. Utility vs stability vs hydro dynamic efficiency. You have to pick where that balance point is that suits your requirement and adapt accordingly. One end of the spectrum are the big PAs and at the other racing surf skis. Folks still tip PAs. Cant carry anything on a surf ski, tend to carry too much on a PA
If you practice a lot of falling out and climbing back on then fear of stability dissipates, and your odds of over reacting which often causes the spill in the first place goes away
Following up on one of your original concerns, if have soft sand to regularly deal with then beach wheels are your saviour. Any fully loaded fishing kayak can be quite heavy
