It is currently Fri Apr 19, 2024 12:08 am
 Post subject: foam blocks in outback
PostPosted: Tue Jan 08, 2019 11:46 am
I removed the foam blocks to make sure the inside of my kayak was clean enough to get into a SoCal lake with quagga mussel restrictions. I guess I should have made better notes as to their location for reinstallation. Is there a diagram or any info on their location. I think I got them close, but a couple of them are really really tight to get in. Thanks in advance. Mike
PostPosted: Wed Jan 09, 2019 5:53 pm
On the 2019... Each of the two blocks go behind the scupper tubes. One on each side. And they zip tie to each of the tubes.
PostPosted: Fri Jan 11, 2019 10:11 am
thanks Matt, I guess I should have stated in the first place I have a 2016 Outback. There were 6 blocks I think.
Mike
PostPosted: Fri Jan 11, 2019 1:02 pm
PostPosted: Sat Jan 12, 2019 8:33 am
Thanks Matt. Zackly what I needed
PostPosted: Sat Jan 12, 2019 10:15 am
What is their purpose?
PostPosted: Sun Jan 13, 2019 8:21 am
A few years back, flotation in the form of blocks was added to all Hobie Mirage drive kayaks in case the hull is breached/full of water :wink:
Dr.SteelheadCatcher
Warrenton, OR
