It is currently Wed May 12, 2021 11:04 am
PostPosted: Mon Apr 13, 2020 9:31 am
360 MirageDrive Adjustments
Proper cable adjustments are required to prevent premature wear and damage to the 360 MirageDrive. Adjustment of the Global Adjustment Screw and the Idler cable will keep the pedaling loads even on all cables.
The Global Adjustment is accessed through a hole in the bottom of the drive and is for tensioning the internal lines inside the Drive. The Idler Cable connected the left and right pedal and is a stainless steel cable coated in protective black plastic tube housing.
A loose idler cable can cause the forward internal cables to be overloaded. This may also cause a clicking sound from inside the drive. View this short how-to video for proper tensioning adjustments.
A quick how-to for adjusting the MirageDrive 360:
