It is currently Thu Jun 22, 2017 6:23 am
PostPosted: Tue Jul 03, 2007 12:13 pm
The beaches on the lakes I use are rocky. I am very reluctant to beach my H16 on these beaches, or temporarily on a concrete boat ramp. I'd never drag my H16 up onto a concrete boat ramp or across a rocky shore. Am I being overly cautious? My hulls are in great shape, not worn, and not scratched.
I am wondering if anyone has any thoughts about using a product like the Keel Guard Protective Tape on the leading edges of a Hobie with fiberglass hulls? http://www.keelguard.com/ I'm not sure if this product would conform the angles of the Hobie hull, as it is primarily designed for powerboat / bassboat keels? I'm thinking about putting 5-6' lenghts on the front 1/3 of each hull.
I'm not a racer, and not too concerned about losing a little performance. It would be nice to not worry about the hulls getting scratched or worse when you want to pull up on shore to take a break or have some lunch.
I have another Hobie with the Rotomolded hulls, and it is a joy to beach wherever and whenever you want. I'd like to make the H16 a little less fragile.
Any thoughts are appreciated. The forum is a great place to learn before doing something I might regret. Thanks.
'08 Hobie Wave, Hobie Adventure Islands
PostPosted: Thu Jul 05, 2007 1:41 pm
How about getting an anchor and a set of beach wheels? Put the boat in the water using the beach wheels (rather than dragging). Once it's in, anchor it a little ways off shore so you don't have to beach it when you take a break. Put a mooring ball on the anchor line for when you're sailing. You would also probably want to run a line from the anchor to the beach just as a safety line.
Just a thought.
 Post subject: Beach Wheels / Anchor
PostPosted: Thu Jul 05, 2007 2:20 pm
Thanks for the input. I've more or less come to the same conclusion.
PostPosted: Thu Jul 05, 2007 5:41 pm
"Back in the day" when I was sailing in So Cal we had the same dilemma when we headed up to Big Bear Lake for the annual regatta. The place we launched from was a rocky section of the lake. After doing the tag-team boat launch and recovery thing my first time up I decided to make a portable system out of PVC. It had two 2" crossbars wrapped with ribbed rubber matting that were held together by two 1" pieces of pipe that were pressed into four T's in the 2" pipe sections.
The smaller pipes nested in the larger pipes and were held in with end caps for portage, just bungied to the trailer and nestled up against my sail box. Once the thing was put together and sitting on the beach or rocks the hulls would sit on the black matting which had enough bite to keep my Hobie from sliding off on it's own, but were still slick enough to make pulling the boat on and off a breeze.
The thing worked pretty well at Big Bear, Lake Perris and other places where the "beach" was more dirt than sand. It also did a good job of "saving" my spot on the shore.
PostPosted: Thu Jul 05, 2007 6:15 pm
Try old strips of carpet. They do get dirty but I just threw them in the back o the truck. I have launched off a steel sea wall with the carpet as well.
DVL 1989 H-18 Worlds Boat, Magnum Wings & Spinnaker
dale.vanlopik"at"att"dot"net
PostPosted: Sat Jan 08, 2011 12:50 pm
I like the simplicity of using carpet. But of course that's not permanently attached to the hulls. So you have to lay out the carpet before beaching. Kind of like you'd have to get the beach wheels ready, before you hit the beach/ramp.
Using KeelGuard tape is still on my mind. Yes it's pricey. But if it worked, it might be easier to do than layering up fibre, resin, and gelcoat.
-Roland
Sailing vintage Hobie Cats in West Africa.
PostPosted: Sat May 23, 2015 9:49 pm
Hello fellow Hobie kayakers, I know the thread has been idle for a while, but...
For years I've been trying to find a solution trying to protect all my Hobies (Outback 2013, Outback 2014 and finally now... my brand new Hobie Outback 2015
Must have spent countless hours online doing research on possible, doable and above all effective solutions to protect both stern a bow keels on my Outbacks. Result... Never found anything truly worth while, either because after some research review show products not being really effective as they would offer little to no protection OR other products out there were too expensive and required some tweaking (forget about the fact you if you make a mistake or the solution don't actually work... that would be an expensive prototype)
Now that I came up with what I feel as being PERFECT solution (and cheap I should add) figured I should share...
PLEASE DONT TAKE ME WRONG... By no means I think this is better than anyone's else solution (a perfect solution i and will always be what works for you) but... I'm really happy with it and will protect my new Outback when loading/unloading the kayak to/from my truck roof rack and launching/arriving to the boat ramp (concrete)
You will notice the after making these two pieces the 32oz jar (approx. $30) is still over 3/4 full (this was also after making a couple nose/tail protectors for my longboard skateboard) - Pigment Pack (approx. $12)
Total cost for BOTH pieces: LESS $5
(Please note: MATTE scotch tape was used to prevent morphing plastic from adhering to shape roller, kayak and everything else...)
BTW you can make this in whatever color you'd like...
