It is currently Wed Apr 24, 2024 4:42 am
 Post subject: harken cleat
PostPosted: Sun Sep 12, 2004 4:42 pm
One jaw, on the cleat on my harken low profile blocks is not workling.Seems like the spring is gone.Is there a fix?
 Post subject: Spring
PostPosted: Sun Sep 12, 2004 5:43 pm
First try loosening the screw and nut that hold it to the blocks or swivel plate. Try flushing with water. There is an internal spring that may have jumped off or possibly it is just dirty. You can pop the red base plate off of the jaw set if you remove the jaws from the block. Inside you will see the two small springs that work the jaws.
