It is currently Thu Jan 18, 2018 5:17 pm
 Post subject: Cat Trailer box
PostPosted: Wed Oct 13, 2004 9:47 am
I recently acquired a Trailex traler and want to build an aluminum sailbox. I have considered using Diamond plated aluminum like the truck boxes are made of. I have found a local supply of material, but am not really sure what guage I should use. Anyone else ever built one of these.
Light is right :!:
One hull up..!
JSD
PostPosted: Wed Oct 13, 2004 2:10 pm
I wouldn't worry too much about the guage. If you use some aluminum "angle iron" to build a frame and then (AC Tig) weld the plating on it should be plenty strong. :)
Warm regards,
Jim
"A little crazy but with big balls."
PostPosted: Wed Oct 13, 2004 8:48 pm
I have a trailex trailer with a homemade galvanized box on it. I didn't make it, so I can't tell you the guage. But the key element is that the sizes are rigid enough to support the weight of the cover. The taller and longer the box, the heavier guage you will need.
But since you have an all aluminum trailer that's already light, go for it! Make it bulletproof!
2001 H16E (European Boat) Sail #108348 Cabo
1991 H14T
2006 Bravo
Users browsing this forum: No registered users and 6 guests
