It is currently Tue Mar 28, 2017 7:22 pm
 Post subject: Flexing Hulls
PostPosted: Sun Oct 24, 2004 8:58 pm
When I lift up one hull at the bow there is quite a bit of movement (twist) before the other hull comes off the ground. Is this normal? How much flex is bad? I can see the hulls moving differently too out on the wter - flexing a little as she rides the swell.
Any info/suggestions appreciated. The H16 is about 15 yrs old and in very GOOD condition. Thanks, J
PostPosted: Sun Oct 24, 2004 9:18 pm
Your hulls aren't flexing - the trampoline frame is just loose. Unless you're racing, it's not a big deal, but it will get worse.
First thing to do is lace the tramp as tight as you can get it. The sidebars will bow inward if you get it tight enough.
If that doesn't tighten the frame up enough to your liking, you can shim the pylons where they go into the castings. Hobie makes a kit with brass strips, or you can use aluminum strips cut from soda cans. I've even used strips of vinyl siding.
If that doesn't work, you can glue the frame together. That's kind of the ulitimate stiffening method. It does make it hard to get the boat apart if something breaks.
You can seach this forum for ways to do any and all of the methods listed above.
PostPosted: Mon Oct 25, 2004 6:38 pm
Thanks for that advice MBounds, I'll check it out in a few days.
