It is currently Fri Mar 29, 2024 5:37 am
PostPosted: Fri Jul 11, 2008 3:20 pm
After having my two AI’s taking up more then most of my floor space in the garage, I came up with this stand-alone rollout system. I needed the ability to move the yaks in and out as needed with little issues. So far it seems to be working great. I used 1-1/2â€
PostPosted: Fri Jul 11, 2008 4:49 pm
Looks nice and efficient Warren. I made a single story version like yours using a metal cart. My AI slides neatly between the wife's car and my workshop.
Jim
Clearwater, Fl
PostPosted: Fri Jul 11, 2008 7:06 pm
Is there any concern about the three cross pipes that the hull is resting on in the sense it could deform it? I was told that the AI didn't like to be stored flat unless in a cradle.
PostPosted: Fri Jul 11, 2008 7:30 pm
I don't believe there is any concern with deforming. I have only had them on the racks for a short period. The weight feels like it s distributed fairly even. I will keep an eye out for this issue. Thanks for the heads-up.
PostPosted: Fri Jul 11, 2008 8:04 pm
I store mine flat and have had no problems with the hull. Mine rests on foam which is on the cart. Here's some pictures from a thread I contributed to last year. The foam I use now is thicker and I removed the toolbox from my truck which made a big difference. http://www.hobiecat.com/community/viewt ... ght=#40665
Jim
Clearwater, Fl
PostPosted: Fri Jul 11, 2008 8:12 pm
I have to tell you...this is a great forum....lots of great ideas . I have a lot of old pvc pipes from a cancelled customer project that I am going use now with your ideas...great set up..!!!!
