It is currently Mon Apr 24, 2017 4:39 am
PostPosted: Wed Sep 24, 2008 11:22 pm
Just got the hobie snuffer and at first look you have to rivet it to the pole? I have used the SNU system which was just lashed to the pole and worked just fine. I don't like drilling more holes then absolutely necessary.
Has anybody figured out a way around this? I am tempted to use those holes on the ring to lash it to the pole, not sure if this will be rigid enough.
Seamus
PostPosted: Thu Sep 25, 2008 6:08 am
Mine mounts with a single screw. I'd recommend using more. Riveting it would work too.
PostPosted: Thu Sep 25, 2008 7:43 am
Replace it with the snu and sell off the stock snuffer or keep it till you upgrade.
Rich Vilvens
F-18 5150
R.Vilvens@yahoo.com
PostPosted: Thu Sep 25, 2008 8:51 am
Seamus
Call Andy - there is nothing wrong with the stock snuffer, we tried both and use the stock one. He has found a way to attach it without drilling into the pole.
PostPosted: Fri Sep 26, 2008 7:35 am
I like the stock snuffer after sailing with the snu all season. have a regatta this weekend so riveted it on last night. it's on there now and won't be coming off.
Thanks for the input
