It is currently Wed Mar 29, 2017 2:31 am
 Post subject: Map pouch screws
PostPosted: Sat May 09, 2009 12:50 pm
I need to do some modification on the side map pouches. Does anyone know whether the screws just turn with a screwdriver from the top, or is there a nut on the inside that needs to be backed with a wrench or something? It would be nice to not have to have someone reach in and up there to keep a nut from turning.
 Post subject: Re: Map pouch screws
PostPosted: Sat May 09, 2009 3:47 pm
The mesh over the pockets is attached by selftapping screws that are easy to remove. I've used a cordless drill to remove them. Just make sure it's in reverse! :wink:
PostPosted: Sat May 09, 2009 3:51 pm
Thanks, I'll try it out.
PostPosted: Sat May 09, 2009 4:01 pm
They are just a screw. I have removed the mesh part from my Revo just using a screwdriver. I then put the plastic surround (without the mesh part) back with the same screws to cover the holes again.
PostPosted: Thu May 14, 2009 1:59 pm
My pockets are fraying and need to be replaced. The saltwater has probably worn them out even though I wash to A1 thoroughly with water after ever use. I was able to unscrew them easily by hand. My worry is that they won't tighten properly and that I might need to use a washer to ensure they don't come loose.
Better to be a live donkey than a dead lion!
