It is currently Mon Jan 22, 2018 6:11 am
PostPosted: Thu Nov 12, 2009 11:48 am
I just got my PA home and shoved my new style cart (wide but with old style wheels :cry: ) and the prongs only just make it through the hole. Not eneough room to thread the new clip through.
Am i doing it wrong
PostPosted: Thu Nov 12, 2009 12:11 pm
The Trax carts were just long enough, but after a mold change for the hull, not long enough for the keeper pin to work. The newer Trax 2 carts are now longer as is the standard cart. This is a VERY recent change.
For your cart... The carts works... the keeper does not.
If still new, the dealer may consider a swap. The cart you have works for every other Hobie model. Fyi... The Trax 2 is a bit more expensive.
PostPosted: Thu Nov 12, 2009 3:24 pm
awww. :x
i used it a few times allready
PostPosted: Thu Nov 12, 2009 4:15 pm
You can always ask them. Maybe sell to another Hobie owner?
PostPosted: Fri Nov 13, 2009 7:40 pm
My cart is the same as yours and I fixed it to work by extending one "leg" of the cart that the pin is on. I found some scrap aluminum that fit rather tight, and jammed it the cart's material. Extended it about two inches maybe and drilled the hole in the new material.
Yakkingaway
Portsmouth, VA
Users browsing this forum: No registered users and 6 guests
