It is currently Sun Jan 21, 2018 4:31 pm
 Post subject: Storing Your Hobie Kayak
PostPosted: Mon Nov 30, 2009 2:37 pm
STORING YOUR KAYAK
IMPORTANT: Do NOT hang your kayak from the bow and stern handles. These handles are designed for carrying the kayak, not for hanging for long periods of time. The plastic will slowly stretch over time and possibly even eventually fail which will create a hole.
When storing your kayak, it is important to be sure that it is well supported.
ON THE GROUND OR A RACK
You can store your kayak upside down resting on two crossbars. The rails of the kayak are very stiff and can support the weight easily. Padded crossbars will reduce the chance of any scratches or marks on the rails.
If you must store it right side up, use cradles or something that is shaped to the contour of the hull. It the kayak is resting right side up with little to no support, this puts the entire weight of the kayak on one point on the bottom and possibly cause a flat area to develop. We do offer custom molded cradles for the Adventure Island and the Pro Angler.
HANGING
If you plan on hanging your kayak from a ceiling, a minimum of one inch webbed strapping should be used to spread the load of the kayak over more area. Using rope to support is may leave dents in the rails, especially in the heavier kayaks. Best if stored upside down with the strap loads on the stiff cockpit rails.
REMOVING DENTS CAUSED FROM IMPROPER STORAGE
If you do see a dent or flat area from improper storage, you can remove it fairly easily. For minor dents, put the kayak in the sun with the dent up. The plastic will soften slightly and the plastic will return to its original shape. For more severe dents, pour near boiling hot water over a towel on the dent and pressurize the hull. The air pressure will push on the softened plastic, returning it to its original shape. A great way to put air pressure in your hull is to hold a shop vac exhaust flow into the opened drain plug. Do not force more than a pound or two of pressure into the hull without the possibility of the pressure easily escaping. Pressure in the hull can cause damage.
