It is currently Wed Apr 24, 2024 5:29 pm
Post new topic Reply to topic  [ 75 posts ]  Go to page 1, 2, 3, 4, 5  Next
PostPosted: Tue Mar 16, 2010 7:52 pm
Is there any chance that, in the future, Hobie will create a retro fit kit to adapt the Tandem Islands Aka Crossbars to the AI? I like the looks of the TI's Crossbars and they look like they would be stronger and easier to install. Has there been any discussion of retrofitting these crossbars to AI?
Thanks Matt!!
Sterling
2008 Papaya Adventure Island with Roller Furler Jib
Post about my jib
viewtopic.php?f=69&t=20991
PostPosted: Wed Mar 17, 2010 4:05 am
I was wondering the same thing, its probably the most annoying part of rigging up the AI is with those pins on the current crossbars.
PostPosted: Wed Mar 17, 2010 10:00 am
Likely a 2011 feature for the AI.
PostPosted: Thu Mar 18, 2010 1:53 am
sweet hopefully a retro fit is possible!
PostPosted: Mon Sep 06, 2010 11:05 am
Hi I ordered a AI in July, and received it on Aug 20, 2010, it has the AT Crossbars and outriggers. The newer rudder and lever handle. It does look stronger than the old system, and you just slide the pieces together, one of mine stuck when trying to take it out.
Bryan
PostPosted: Mon Sep 06, 2010 10:05 pm
It sometimes helps to swing the ama back and give a little twist when removing it (if binding). 8)
PostPosted: Tue Sep 07, 2010 6:52 am
Do the amas clear the water when you are pedalling with the sail furled?
PostPosted: Tue Sep 07, 2010 1:38 pm
S.Yoars, is that aluminum oxide inside those new Aka clips?
The Wind Is Your Friend...
PostPosted: Tue Sep 07, 2010 1:39 pm
Bryan
Pictures Bryan. Bust out the pictures.
PostPosted: Thu Sep 09, 2010 5:14 pm
The "kit" would be (2) crossbars, and (4) akas... pretty expensive upgrade.
PostPosted: Fri Sep 10, 2010 1:54 pm
And don't forget adding the TI Amas, which is where this conversation leads. $$$!
(BTW, we have tweakers out here that are doing this now with the older Akas/xbars).
Matt, can you confirm if the new system has steeper Aka angles and therefore higher Ama clearance? Would the AI kit follow this change?
Can someone post a comparison photo with the AI/TI Akas side by side or overlayed?
PostPosted: Fri Sep 10, 2010 2:34 pm
This will not fit TI amas. The crossbars are spaced differently, so folding amas would be an issue.
The AI version also has AI ama depth.
PostPosted: Fri Sep 10, 2010 3:41 pm
Thanks Matt. And welcome back to the land of Sonic Burgers. :wink:
In this application, the Akas are braced and do not fold anyway. For tramp owners this may be less of a problem too. It would allow for more carry capacity and alternate outboard seating rigs. We'll see what happens.
It's really hard to tell those imagineers in the skunkworks that something can't be done. Just makes them try harder. :lol:
PostPosted: Fri Sep 10, 2010 3:53 pm
Ah Nohuhu, I share your dream of being able to pedal the boat in AI mode almost as fast as it can go in Adventure mode.
PostPosted: Fri Sep 10, 2010 8:41 pm
I suspect little if any angle difference between the AI and TI akas. Take a look for yourself:
The TI sits higher in the water, thus lifting the amas higher (these pics don't provide a good comparison on this matter since the TI is being soloed from the front, thus depressing the bow). Additionally, the much higher capacity of the TI easily supports the weight of the amas, akas and passengers without much settling. Finally, with the TI's flatter, wider bottom, the heeling fulcrum point moves more to the lee side, allowing more initial heel but less weight transfer to the leeward ama (whereas the AI heels more about its longitudinal axis, dropping the akas closer to the water for a wetter ride). I'm not sure if that last part came out very clearly, but something to contemplate anyway. :D
Bottom line, if you put the TI amas and akas on the AI I don't think the heavier, longer amas will ride clear of the water -- more likely the opposite. You might get a faster ride though (sailing). But perhaps the land of Sonic Burgers will prove otherwise! 8)
