It is currently Wed Dec 06, 2023 7:51 pm
 Post subject: mast chip
PostPosted: Mon Mar 06, 2006 4:59 pm
The mast chips on my new h16 last only one sail. Also,the dolfin striker rod is visible at the bottom of the casting. Is this nomal? And the chip often moves when the mast is raised. Any tips?
PostPosted: Mon Mar 06, 2006 7:05 pm
Do a search on this site for "mast chip" - it's been discussed a lot.
Or you can come to the St. Andrew Bay YC this weekend and we can explain in person. There will be a lot of good Hobie people there for MidWinter's East.
 Post subject: Make your own
PostPosted: Mon Mar 06, 2006 8:46 pm
S Miller:
When I had my 16 I made my own chips. Get a piece of pipe the right size and put it on a grinding wheel. Sharpen it to a sharp edge. Go to a plastic supply company and buy Teflon in sheets, it is cheaper. Use a hammer and punch them out like a cookies cutter. MUCH cheaper that way.
Doug Snell
Hobie 17
Soon to be Nacra A2
www.tcdyc.com
PostPosted: Tue Mar 07, 2006 6:50 am
Yes it is normal to see the top end of the dolphin striker post in the cup of the mast base.
There are contured bearings sold by the hobie dealers or may be Muray. Those might stay in plase better than the flat chips. For a while I use a hollow type of golf ball (not user what they intended to be used for). I cut them apart at the seam - they fit very nice - and cost about 5 cents per bearing. I would not use the golf ball idea if you keep the mast up for many weeks at the time.
Patrick
if you can't find a local plastic supply house checkout either of these industrial suppliers:
http://www.mcmaster.com
http://www.mscdirect.com
You can find all kinds of stuff here for repairs or making gadgets.
Nick
Current Boat
In the market
Previous boats owned
'74 Pearson 30
'84 H16
'82 H18 Magnum
St. Louis, MO
 Post subject: Chips?
PostPosted: Tue Mar 07, 2006 10:32 am
The striker post should be visible, but it should not be poking up into the cup. It should be flush with the bottom of the radius.
New boat? New boats from Hobie USA and Australia come with the "chip keeper". This is a series of holes drilled into the cup. The chip presses into the indents and holds the chip. You have to pry them out. We sailed the '04 Mexico 16 Worlds boats the equivalent of full years normal use over the 10 day regatta... never had to replace a chip.
PostPosted: Fri Mar 10, 2006 3:21 pm
you can always use 2 liter coke bottle lids :D
Tom & Nancy Page H20 803
PostPosted: Sun Mar 19, 2006 12:45 pm
The alternatives all work but they have their own issues. The teflon chip is still the best solution because it has less friction and does not cause any wear to the mast cup or mast base. The key is to update your mast cup to match that of the new Chip Keeper version to which mmiller referred.
The Chip Keeper is incredibly simple to duplicate. All you need is a Dremel type tool and a small square end metal cutting bit (like a tiny end mill). Take a look at the image I created. You cut 4 or 5 half-moon plunges into the lower portions of the mast cup. That's all it takes because you only need to create some indentions so that there will be more friction between the mast cup and the chip than between the chip and the mast base.
Updating my 2001 boat took only 10 minutes last summer. I've had no chips blow out since the mod. :D
PostPosted: Mon Mar 20, 2006 10:38 am
Golf Ball Whiffle balls cut in half. Buy a ton of them, keep them in your gear box with a putter and wedge in case the wind sucks you can play with them.
PostPosted: Mon Mar 20, 2006 12:36 pm
We go to the local plastics supply house and buy scrap sheets pieces to cut our own. Teflon works great (if you can get it).
Love the golf/wiffle ball idea, and let's tee it up some time. My old neighbors and I became very good at wiffle golf on the Saturdays we were "supposed" to be babysitting. Quite the site, driving down our street, to see us in the yards in full attire, pushing kid's in strollers and pullcarts with clubs.
Fleet 297
