It is currently Tue Aug 04, 2026 10:08 pm
 Post subject: drive off
PostPosted: Thu Jun 10, 2010 12:25 pm
Hello
photo drive off
This is a default?
thank you
 Post subject: Re: drive off
PostPosted: Thu Jun 10, 2010 1:32 pm
Those look like the older plastic sprockets using the allen set screw.
I would say now is the perfect time to upgrade to the "new and improved" V2 sprockets that use a threaded mast and have a brass insert. :)
Especially if you are using turbo fins. The notch cut in the old style masts can be a weak point under stress.
The threaded V2s are so much easier to deal with than the worrisome allen set screws.
PostPosted: Thu Jun 10, 2010 2:11 pm
Seeing that we have had the threaded mast and sprocket setup on the drives for a couple of seasons... I have to guess these failed parts are a bot older than that.
As Yak said... upgrade. There is a kit that comes with two masts and two sprockets (either standard or Turbo).
