It is currently Fri Jun 19, 2026 8:50 pm
PostPosted: Mon Sep 06, 2010 4:34 pm
Is the eVolve compatabile with the mirage i9s and what compressor can I use to inflate/deflate it? Yesterday was my first time out and neither of my Coleman compressors worked with it and I found it very cumbersome trying to get all the air out of it...any suggestions? thanks
PostPosted: Tue Sep 07, 2010 6:42 am
Must be doing something wrong. The i9 is easy to inflat with the hand pump. Maybe the valve is stuck or partically open and slowing down the exit rate of the air?? Good luck and have someone check the valves for you.
PostPosted: Fri Sep 10, 2010 8:58 am
There will be an eVolve kit specific to the i series soon. This will be a drive mount only. You can not mount on the i series rudder.
Yes, the hand pump is required for full pressure unless you have a specific electric pump that gets high enough pressure.
