It is currently Sat Mar 07, 2026 2:35 am
 Post subject: Camera mount suggestions
PostPosted: Wed Aug 31, 2011 12:18 pm
Has anyone come up with a good system to mount a camera?
I'd like to use one of the back rod mounts on my Outback to fit a monopod of about 3 feet height. This would support either a video or still camera. But I'm not able to locate a product that mounts this way. The commercially available monopods I've found seem to all require a separate mounting system.
Thanks for any input.
PostPosted: Thu Sep 08, 2011 7:48 am
YakAttack Panfish mount is what I use- and you have a separate mounting system, but it is the cat's meow- has a friction feature that allows you to pan the camera up to 360 degrees with the mount locked down securely-
Moss Green Hobie Outback
Yellow Ocean Prowler 13
