It is currently Fri Jun 19, 2026 11:13 pm
PostPosted: Tue May 27, 2014 3:27 pm
Not sure where to mount the fairlead. If I do like the instructions say, the pedal hits the line, so I won't be able to take a full stroke. Any ideas or photos of late model Oasis installs?
PostPosted: Tue May 27, 2014 3:39 pm
Only options are to position more forward or reduce pedal stroke.
PostPosted: Tue May 27, 2014 10:50 pm
The furler line should be routed around the cockpit. Position the fairlead forward enough to clear (or barely touch) the pedals when in the #7 position. The fairlead should split the angle where the line turns at the front corner -- it will be oriented approximately 45 degrees relative to the centerline. Lay it all out before you drill to make sure it looks good. 8)
