It is currently Fri Jun 19, 2026 11:13 pm
PostPosted: Sun Feb 08, 2015 9:35 am
I picked up this steel cart on Craigslist yesterday for $20. It’s 99L x 22W and weighs about 35-45 pounds. This has 4” Colson casters, two with brakes. I am going to use it to make a garage storage cart for my 16 foot Adventure and am looking for some input as to how you folks would adapt this cart for my purposes.
Right now I store the yak upside down on sawhorses and it is a pain to get it out of the garage and onto my truck. I wanted something to roll out in the driveway or street. I'm undecided on what to add to the cart. I was thinking of 10 foot long 1.5 or 2” PVC tubes running along the grooves on the bottom of the hull. I’d build a frame to bring them up just above the 37” high handle. That would make it easy to work on, not to mention closer to the roof of my camper shell.
PostPosted: Sun Feb 08, 2015 7:31 pm
I would look into mounting two parallel schedule 40 PVC pipes in which the hull is set into.
Assuming you used 2 each, 2 7/8" OD pipes, mounted to fit either side of the center hull shape would nicely support the hull.
Dr.SteelheadCatcher
Warrenton, OR
