It is currently Mon Feb 02, 2026 3:29 pm
 Post subject: Pro Angler 17t
PostPosted: Mon Jun 01, 2020 12:58 am
Hey all, developed a problem with our rudder on the pro angler 17t not releasing and dropping into the vertical position. It can be pulled down by hand and it can be pulled up into it's up.position by the release cable. The spring is still visible but does not seem to have any tension on it....Thoughts ?
Tim
 Post subject: Re: Pro Angler 17t
PostPosted: Mon Jun 01, 2020 2:07 pm
Hard to diagnose with such limited info - love to help better with more details - have you given your dealer a call perhaps they can take a look at it for you.
PostPosted: Mon Jun 01, 2020 2:17 pm
Pull the rudder apart (2 small sister flat head screws) and check the spring / it's part # 84504001, if you need a new one order from a dealer.
Jacques Bernier
http://www.hobie.com/
PostPosted: Mon Jun 01, 2020 8:25 pm
Thanks guys, spoken to dealer so a clean out first and then see if a new spring is required.
