It is currently Mon Nov 03, 2025 9:54 pm
 Post subject: Idler Cable problem
PostPosted: Sun May 16, 2021 3:50 pm
Hi everyone,
The idler cable on my drive broke, i noticed the drive still works without the idler cable. Is it OK if I keep using the drive without an idler cable? Thanks.
By the way, also, how to adjust foot strap of the pedal? When I wear bigger shoes i need to loosen the footstrap. Thanks.
 Post subject: Re: Idler Cable problem
PostPosted: Mon May 17, 2021 11:12 am
It will still work but adds a lot of load to each chain. The idler balances the load on each stroke.
You pull the strap tab outboard to release from the peg on the pedal, adjust and then press back on.
