It is currently Mon Feb 02, 2026 7:11 pm
 Post subject: Found for free
PostPosted: Mon Nov 05, 2018 3:22 pm
SE? SX? It's an 88. Found in ct owner didnt want it, thoughts?ImageImage
Sent from my SM-G950U using Tapatalk
 Post subject: Re: Found for free
PostPosted: Mon Nov 05, 2018 4:17 pm
Hobie 18 with "Magnum" wings.
https://www.hobie.com/forums/viewtopic.php?f=13&t=12780
- Magnum Wings... welded frame, length of tramp area.
- Hobie 18 Magnum... add (welded frame) "Magnum" wings (1984-85 ish).
PostPosted: Tue Nov 20, 2018 1:17 am
How much work do you want, and how much money can you spend getting the boat seaworthy again? Maybe take it for parts? The wings alone have value.
PostPosted: Tue Nov 20, 2018 6:26 am
I am envious of you. I would have taken it home right then on the spot!
As Skipshot implied, you could be the proud owner of a (small) hole it the water into which you may now start throwing money.
If it's not for you, please message me with the contact info. I can be there this weekend to haul it away and park it next to it's mate... :D
PostPosted: Sat Dec 29, 2018 6:38 am
I took it home will part out another 18 to get this one going it's in really good shape compared to the one I'm going to part out. With the exception of this hole. I do need help with some fiberglass repair. Or someone hands on teach me
If anyone has a good video on how to set up the 5:1 downhaul I got from murrays for Christmas. Confused how it goes through the boom.ImageImageImage
PostPosted: Sun Dec 30, 2018 6:24 am
Previous thread that may be of some help.
https://www.hobie.com/forums/viewtopic.php?f=13&t=33302&p=131355&hilit=Repair#p131355
PostPosted: Thu Jan 31, 2019 1:54 am
It does not go through the boom; the boom's gooseneck goes through the downhaul lines. After connecting the lower blocks of the downhaul to the mast, attach the downhaul to the mainsail tack, then connect the boom to the mast through the downhaul lines.
