It is currently Sun Feb 08, 2026 11:16 am
PostPosted: Sun Jul 19, 2020 12:04 pm
I'm trying to install a 6" long transducer on my compass (Garmin Striker 4)
I can attach it with modifications to the plate, but it will stick out past the end of the plate.
I can still reconnect the plate to the kayak, but there won't be a gap between the plate and the transducer...
will this effect the accuracy of my readings or cause any interference?
PostPosted: Wed Jul 22, 2020 1:45 pm
Laker29 ... I just installed a Garmin Striker 4 CV on my 2018 Compass. The trick is to modify the plastic transducer plate on the transducer by cutting the extra plastic that extends beyond the body of the transducer. Then you need to cut a little bit of the posts on the transducer cover (kayak) to fit the transducer in. Finally you need to connect the transducer assembly to the cover posts ... use a pair of 2 Hole Straps used to hold 1/2 pipe ... it's in this video ... https://www.youtube.com/watch?v=QKIU2lFFBjg
There will be a little bit of the transducer extending beyond the end of the transducer (1/2 inch ?) and you need to "force" the screws in that hold the cover to the hull, but not a lot.
Everything else is by the book to wire up you FF.
Any specific questions get back to me
PostPosted: Wed Jul 22, 2020 2:45 pm
I have Raymarine Dragonfly on my Compass / Revo and it sticks out 1-2" behind plate and no issues so far. With the Dragonfly I had to Dremmal off the plastic arms off plate, but no issues.
