It is currently Wed Apr 22, 2026 8:48 am
 Post subject: odd noise
PostPosted: Mon Jul 21, 2008 8:59 am
I spent a lot of time on my boat this weekend, a 1982. Every once in awhile I hear an ominous sounding "clonk" that seemingly comes from the forward, starboard hull. There is no rhythm to it. Just every once in awhile....clonk! I can't detect any play in the forward pylon (although I have shimmed my pylons with beer cans). The boat seems pretty rigid otherwise. I sail in fairly choppy seas. Any thoughts on this? Just don't want to ignore it and then have some catastrophic failure three miles out.
PostPosted: Mon Jul 21, 2008 9:44 am
I heard this a lot when I took my boat apart and re-finished the hulls. In my situation, it was the large, styrofoam blocks inside the hulls making the noise when I rotated the hull.
My best guess based on your description.
Eric
H16
Sail# 11500
PostPosted: Mon Jul 21, 2008 12:22 pm
I assume these are for flotation. Were the blocks loose? Is that normal?
PostPosted: Mon Jul 21, 2008 12:39 pm
I'm almost positive the foam blocks are loose in the hulls. Mine makes that clunk sound when I flip the boat over.
James
86' Redline Hobie 16
Sail # 76909
PostPosted: Mon Jul 21, 2008 12:53 pm
The foam blocks are for positive flotation (if the hull fills with water, it'll still float - barely).
They are loosely fitted into the space between the pylons and will clunk around, especially if you turn the boat upside down.
