It is currently Thu Mar 05, 2026 8:45 pm
PostPosted: Fri Jul 31, 2009 3:09 am
I have a 92 ish H16 Today upwind in 15+ knots twin trapped I notices the lee bow really flexing/ twisting
Is this normal?
The prevoius owner had epoxied the frame casting to hull pylons
In have std hobie vinyl tramp with double grommets laced as advised here with pre bent side bars
PostPosted: Fri Jul 31, 2009 8:35 am
How much flex is there if you just lift one bow or stern?
PostPosted: Fri Jul 31, 2009 10:26 pm
OK... lets do a poll.. when you lift your port hull.. how far does it move before the starboard hull moves... come on take the time... and let us know...
•Present boat -1998 Hobie 16 Solana Sails furling jib[/size]
PostPosted: Fri Jul 31, 2009 10:36 pm
I don't know but I noticed mine doing the same thing about two years ago. I only notice it when I'm flying a hull, maybe because that's when I'm really looking at the plane of the boat. I was informed that this was quite normal. It could be happening at other times without me seeing it.
Happy Sailing,
David
PostPosted: Sat Aug 01, 2009 7:46 am
They all flex a little. The more worn the corner castings and pylons, the more flex. I measured one boat that flexed 18" when I lifted one bow on the trailer. Upon closer inspection the pylons were worn to almost paper thin, so we junked the boat.
The best way to fix it is to shim the worn castings with epoxy, then tighten your trampoline as tight as you can get it.
I personally think that boats laced with shock cord wear the corner castings faster. So get some low stretch line.
Sail on!
Sail Revolution
Join us on our new FB Page!
