It is currently Tue Jun 16, 2026 7:13 pm
 Post subject: A few basic questions
PostPosted: Mon Aug 03, 2009 7:59 am
I am just starting out with Hobie 16's and loving it so far. There are a few questions that I have:
1) I have a loose cleat on my mast. What is the best way to deal with this. I believe that it is the jib cleat.
2) If you get water in your mast, how do you get it out? Same hole? What if you capsize and the leak is at the tip. After righting you determine that you have water in the mast, how would you know how to get it out? This is hypothetical, I have not tested my mast for leaks and everything looks good so far, except that one loose cleat.
3) There is a 1" gouge up high in one hull. It might lead to a small leak, what is the best epoxy/bondo to use to repair this. It will not take much more than a tablespoon to fill. How do you finish the repair after sanding, is painting necessary?
4) I have keyhole dogbones, with which end to you hook into the harness?
5) I would like to remove the rudders for a long trailer ride. It looks like you just remove the two bolts on each rudder. My questions is, when I do this what will fall out? What more needs to be removed in order to trailer safely?
6) How do you set the shroud tension. From what I have read it seems that you do not want to have too much forward mast rake. Where do I set this to get good a reasonable first guess?
7) My sails have number 356 on them. Are they antiques? :)
Thanks in advance for all your help,
-Brad
PostPosted: Tue Aug 04, 2009 7:07 am
You'll need to re-rivet it. If it's loose enough to get a hacksaw blade underneath it, carefully saw off the rivets (don't want to scratch the mast!) and drive the tails into the mast with a punch. This is preferable than drilling off the heads, since the heat generated can melt the plastic cleat. Re-install the cleat (you'll want to get a heavy-duty rivet gun - not from Home D or Lowes)
A small hole drilled in the mast works well. You can seal it up with silicone or a rivet/casing when you're done. Note that there are foam plugs in the mast at the ends, so the hole should be at least 1' from the end. Bottom of the mast is better - it doesn't see the pressure that the top does when the boat is turtled and is less likely to leak.
Get a can of Evercoat Formula 44 (West Marine). It's a polyester putty that's very easy to work with. After it's filled and sanded flush, you can leave it as is (it's a very light gray) or spray gel coat over it. On an old boat, with faded original gel, I'd leave it as is. You'll never match the color of your boat.
Either one. High one for lighter winds or big waves. Lower for heavy air / flat water.
Easier just to remove the aluminum pins from the gudgeons. Everything comes off in one big piece.
Whole books have been written about this topic and there are many variables to consider. Do a search of this forum for more answers. Rig tension is set with the jib halyard.
Possibly. Depends on if there are missing numbers and/or those are the original sails.
-Brad
I live abour 30 minutes away from you, Brad and I've raced Hobie 16's for 35 years. Let me know if you'd like me to take a look at your boat for you to help you get started.
PostPosted: Tue Aug 04, 2009 12:44 pm
Dear MBound,
I have looked at a number of your posts and been impressed with your knowledge. I also noted the Detroit MI location. I have been sailing with the UM sailing club. They have one jury-rigged H16. Mine is a 1973 and seems in pretty good shape. I would very much like to talk with you offline. My email is orr at umich.edu and I live right next to UM in central Ann Arbor. Drop me a note and I would really enjoy meeting you.
-Brad
