It is currently Fri Mar 06, 2026 5:05 am
 Post subject: Soft Hull Thoughts
PostPosted: Fri Aug 14, 2009 3:46 pm
Soft Hull Thoughts?
I was intending to repair the soft hulls of my H16 just in front of the front phylons using the method described in the Forum with GIT ROT. Someone suggested cutting some of the area out and install a hatch. Good idea or not? I'm thinking if it is structarally soft already this could make it worst? Help!!!!!!
 Post subject: Re: Soft Hull Thoughts
PostPosted: Fri Aug 14, 2009 3:49 pm
I would avoid the hatch idea. Not a good "fix" and complicates the injection process.
PostPosted: Thu Aug 27, 2009 10:07 am
Soft Hulls can be really dangerous.
See this post: viewtopic.php?f=14&t=13308
I also know this from expierence.
Good luck with any repair you attempt.
When life gets windy, reef the sails, tighten the lines, and get ready to smile.
PostPosted: Sat Aug 29, 2009 3:40 am
Yeah the two of us who sail it know exactly how dangerous it is. We had 3 bodies on it one day, 1 of whom was hiking out in a diaper, on a day when the wind was steady 25 kts gusting to lower 30s. The tension on the windward hull cause the hull to buckle and snap inward. We were pretty far out in Lake Huron, in the shipping channel to be exact, when it happened, but we made it back no problem with all limbs intact :D
