It is currently Thu Mar 05, 2026 3:32 am
 Post subject: pylon bolt/nut torque
PostPosted: Mon Oct 10, 2005 10:52 pm
I'm replacing the cracked plastic nuts on my 78 H 16 pylon bolts with new 1/2 X 13 nyloc nuts. How tight should they be?
PostPosted: Tue Oct 11, 2005 5:37 am
Just snug - not real tight or you can crack the castings :shock:
The bolts are in shear, not tension, so the nuts don't have to be tight - they just keep the bolt from falling out.
 Post subject: nylock nuts
PostPosted: Thu Jun 15, 2006 11:41 am
is it ok to replace the nylon nuts with nylock ones
 Post subject: Nuts?
PostPosted: Thu Jun 15, 2006 12:04 pm
You can use the original nylon or the Stainless Nylock.
 Post subject: cool
PostPosted: Thu Jun 15, 2006 12:15 pm
cool i would feel much better with steel
cron
