It is currently Tue Apr 21, 2026 4:21 am
PostPosted: Mon Aug 07, 2006 6:19 pm
Does anybody have any tips on getting the plastic rudder cam adjustment screw out of the casting? I'm afraid to try drilling it out for fear of messing up the threads.
Thanks,
Vince
PostPosted: Mon Aug 07, 2006 9:29 pm
Authorized Hobie Dealer
When they real stuck they are stuck, try a reverse thread bit, we have had good luck with these, wear goggles they tend to shatter! I have also drilled out most of the screw, then taken a pair of needle noise and gotten the rest.
why are you wanting to remover them, we always try to leave them in if possible, we replace the spring and plunger, only the stuck screw if we can't solve the came problem any other way.
Brad Stephens
http://www.sunjammers.com
www.facebook.com/sunjammers
PostPosted: Tue Aug 08, 2006 12:11 am
Go here for a great tutorial. Jeremy at Surf City Catamarans drilled out the screws on my 18 in no time flat.
http://www.surfcitycatamarans.com/plungerscrew
PostPosted: Tue Aug 08, 2006 4:37 am
Thanks for the replies. I've replaced plungers, springs and cams and still have the problem of having to reset the cams at times and wanted to get some adjustment. I've had the boat for over 20 years and have never been able to move the adjustment screw, so I've decided to replace them.
PostPosted: Sun Aug 13, 2006 8:14 pm
Where does one find a reverse cutter drill bit like the one used by Jeremy from Surf City???
Seems to be a specialized drill bit I cant find anywhere!
thanks!
cron
