It is currently Tue Apr 21, 2026 9:18 am
 Post subject: Comp Tip Mast Hardware
PostPosted: Mon Jul 14, 2014 4:44 am
I have a Hobie 16 with a comptip mast. One of the screws that hold the comp tip portion of the mast to the main is broken off inside the mast. When I attempted to remove with easy out the internal rod turns. It eventually pushed out of the other side. What I need is a replacement stainless steel sleeve. It is 5/16" diameter, 2 3/4" long, threaded 10-24.
Any suggestions on where to purchase this?
PostPosted: Mon Jul 14, 2014 1:00 pm
Contact a Hobie Dealer.
PostPosted: Mon Jul 14, 2014 1:05 pm
Thanks...Murrays advised that the part is no longer available. Heading to the machine shop..$40.00
PostPosted: Mon Jul 14, 2014 3:13 pm
Bondo and a couple rivets.
What you have is a VERY old CompTip of the first vintage. Current ones are held in by Epoxy and the and rivets.
