It is currently Mon Aug 03, 2026 8:58 am
PostPosted: Fri May 08, 2015 11:06 am
Hi,
I'm considering purchasing a Hobie 16. The boat is in good shape; however, the current owner indicates that there is a depressed or sunken in spot next to the trampoline support that comes out of the top of the hull. The spot is not soft.
Would this be a deal breaker? I read some through searching on the forum about pylon detachment, but would like some advice on what this spot I've described could be?
Thanks.
Bryan
PostPosted: Fri May 08, 2015 12:31 pm
It is possible that the pylon as pushed into the "shoe" down in the keel. That would not be good, but is also repairable.
From the forums:
I would recommend you download the Sept/Oct 2009 Hobie Hotline magazine. That issue included an article that specifically discussed the repair procedure for fixing a broken pylon shoe.
MBounds wrote:
4 inches? That's a lot of motion. I'm not sure if that can be fixed.
The front pylon (that's the proper term), is part of the deck layup, then when the hull/deck are joined, it rests in a "shoe" that bears against the hull. Here's a cross-section of the assembled hull/deck:
In your case, it sounds like not only has the shoe become unbonded from the hull, the pylon has become unbonded from the deck. This is a major repair, and not really cost effective on a 40+ year old boat.
PostPosted: Sat May 09, 2015 8:51 am
Thanks for the info. Here is a picture of the hulls. Seller says that one of the hulls has a slightly depressed area after the trampoline post.
Also I noticed it has inspection ports. So perhaps the hulls have been worked on before.
PostPosted: Sun May 10, 2015 6:43 pm
Parts boat
JKK
83 yellow/ white decks Hobie 14 Corando turbo
82 yellow hulls Hobie 16 Cat Fever
84 yellow hulls hobie 16 Yellow Nationals
plus a few extras that I'm restoring
PostPosted: Sun May 10, 2015 9:35 pm
I had that happen to my boat, started in July and I kept sailing through August. It gradually got worse and started to show a bit of cracking towards the end. Was a $800 repair but been sailing it hard for the past 3 seasons with no recurrence.
PostPosted: Mon May 11, 2015 2:42 am
cpnsoo wrote:
Parts boat
+1
Hulls are trashed.
