It is currently Mon Aug 03, 2026 2:53 am
 Post subject: Jib Tack Low vs. High
PostPosted: Mon Mar 05, 2018 1:00 pm
What is the advantage of having the jib tack placed down low on the adjuster vs. placing it up higher?
PostPosted: Fri Mar 09, 2018 3:01 pm
Attaching causes more pull on the leach and closing it. Attaching down low causes more pull on the foot and opens up the leach.
ADDICTION
1989 HOBIE 18 SE/sx wings
HOBIE ALTER SIGNATURE MODEL
PostPosted: Fri Mar 09, 2018 7:45 pm
Thanks. In what sinario is it advantagious to place the jib higher? Or, is it best to locate the jib where there is equal tension on the foot and the leech?
PostPosted: Fri Mar 09, 2018 10:31 pm
And here I always thought you just made sure the stripes on the jib and main lined up. Lol. :D
Marty
Lake Martin, 'Bama.
PostPosted: Sat Mar 10, 2018 8:52 am
In very light wind conditions, it is more advantageous to have the jib higher so the head will catch more of the little breeze that there is. In very heavy conditions it is more advantageous to have the jib lower so you reduce heeling moment. In most conditions, you should try to get the leach and luff tensions about equal.
R/Thom
SeaRail 19
Triak
BMW C600
Formerly raced F24 Mk II
PostPosted: Sat Mar 10, 2018 3:56 pm
Excellent! That answers my question. Thank You
PostPosted: Mon Apr 16, 2018 11:12 pm
Also in stronger winds when you mount it on the lowest hole, you want to tighten your jib sheet all the way. If it feels like you can tighten it more then adjust it up one hole. You want the sail to be as tight as possible when fully sheeted in.
https://m.facebook.com/IEhobiefleet30/
Redlands California
2005 Hobie 16 with 2010 euro national sails.
1981 Hobie 16 cat fever
