It is currently Tue Apr 21, 2026 4:10 pm
 Post subject: MMiller
PostPosted: Thu Mar 22, 2007 3:01 pm
MMiller, need your help on deteriorated foam in hull, would this work: cut a inspection port hole, with a long piece of metal clean out deteriorated foam, vacuum, then use epoxy and fiberglass mat mixture and "stuff" it into the void areas using the piece of metal ? Pushing it back until it gets to good foam. Do this in all directions from the access hole. Making the area solid with epoxy & mat cloth. I have done a little fiberglass repair. I saw where someone else asking a similar question. I could angle boat in direction I was pushing mat so the epoxy would stay in place or use a gel epoxy. So what do you think,
Let me thru !
