It is currently Sun Aug 02, 2026 5:38 pm
PostPosted: Sun Sep 01, 2019 4:45 am
Hello, I’m new to the site. Both of the sheaves on my recently purchased hobie are brittle. I know new ones can be ordered, but can someone explain how to replace them? I know the old ones must be drilled out, but do you rivet new one in?
Thanks for any help
PostPosted: Tue Sep 03, 2019 4:54 am
Thanks for any help
I used a pin and ringding, works fine.
PostPosted: Tue Sep 03, 2019 9:25 am
Think you need to be more specific on which sheave you’re referring to. Can you post a pic?
PostPosted: Tue Sep 03, 2019 10:09 am
He already described which one in the post title, Jib traveler car.
I was thinking of using the same type of bolts used to replace the rivet on the rudder cams. I have heard them called sax bolts,and barrel bolts.
Check here
https://www.mcmaster.com/sex-bolts
PostPosted: Tue Sep 03, 2019 10:50 am
Check here
Whichever method you use, the fastener cannot draw tight, otherwise it will pinch the sheave and not allow it to rotate. A lock nut or loctite could work.
PostPosted: Tue Sep 03, 2019 4:49 pm
Lots of different iterations of the “jib traveler car” have been produced for the Hobie 16 between 1970 and 2019, which is why a pic would be helpful to understand exactly which system he has and which specific sheave needs replacing.
PostPosted: Wed Sep 04, 2019 4:14 am
Thanks for your help. I contacted West Coast Sailing . They are sending replacement rivets.
