It is currently Sun Aug 02, 2026 11:39 am
PostPosted: Tue May 19, 2020 7:22 am
Putting the boats together this spring has brought about the debate on how tight the bolts for the bridle wire should be on a 16. One of he holes in my bow is starting to oval a little, and am inclined to make super tight. Some say it should be loose. Thoughts?
PostPosted: Tue May 19, 2020 11:37 am
Snug. Not tight.
The bolt will wedge in place under load.
PostPosted: Tue May 19, 2020 2:45 pm
Understood, but should the bow tang be so tight it doesn't rotate at all, or just loose enough to move a little? One of the holes is beginning to oval a little, and am wondering if I've been under tightening it. I have an 05 hobie 16 btw. thanks.
PostPosted: Wed May 20, 2020 5:19 am
Snug but able to move a little is good. If it's easily loosening during normal use, perhaps the nylock is worn and needs replacement? If the hole is significantly wallowed out, I'd fill it with epoxy/filler and redrill.
Jerome Vaughan
Hobie 16
