It is currently Tue Apr 21, 2026 4:21 am
 Post subject: Cleaning and restoring
PostPosted: Sun May 20, 2007 5:24 pm
Hey all just got a 1981 H16. Has orange hulls and is in overall pretty good shape. I want to get it as clean as possible though.
HULLS-Should I just use rubbing compound/polish on the hull to get it looking new? There are a few scratches can I just use touch up paint on those?
MAIN TRAVELLER: There is some old grease in the track throughout, should I clean this all out and add new grease or is there a dry lubricant or something that would work better?
FRAME: Should I use a metal polish on this to clean it off well and do I need to seal it with anything to protect it?
BLOCKS/PULLEYS/RUDDER MECHANISMS: Is there a lubricant I can use to get them running really smoothly?
MAST: Can I just paint the thing? Doesnt look horrible but a new coat of paint or whatever would be nice.
I know there is a lot but if anyne can answer one or more it would be great, or any other common problem areas, thanks in advance.
PostPosted: Sun May 20, 2007 9:45 pm
MAIN TRAVELLER: Clean out the grease and use dishwashing soap.
BLOCKS/PULLEYS/RUDDER MECHANISMS: Dishwashing soap or a dry silicon. Don't use WD-40 or anything else that's sticky as it attracts dirt.
MAST: Masts have been painted. You may get scratches and dings but it'll look pretty good. Do a search on catsailor.com. There have been numerous discussions there about painting masts and boats.
PostPosted: Sun May 20, 2007 11:18 pm
Hulls: Repair as nec (use gelcoat), buff with 3m perfectit III heavycut . Wax for protection. Sail often, and as fast as you can!!! That'll keep her clean.
Sail Revolution
Join us on our new FB Page!
cron
